View the thread, titled "Hello all - please help - dishwasher inlet into sink tap" which is posted in The Welcome Wagon :) on UK Plumbers Forums.
Could be doable but not with anything like that, you would need a new supply cutting in to the supply to the tap. Might be best to get the landlord to do this. Also avoid tat from ebay, look for "WRAS" mark and go to a plumbers merchant - they will also be able to advise (if you don't go at a busy time). You also need to consider the drainage from the dishwasher (unless you're thinking of running this into the sink - not a great idea) sorry to be a bit negative but asking the l/l is the first thing I would do. Good luck.
I did ask LL but they didnt budge. they are a business company with 200 houses.
Coming to drainage that is what I am thinking to put it in sink..
Is there a way I can use rubber pipe extender which can fit in with a connector from inlet to the tap?
Any pointer to that?
No sorry will blow off or leak
Aah that's what I thought too... 🙁 I am out of ideas .. so trying to get the photo of plumbing unit ..
Your options are either Tee off the water supply to the sink tap, or no dishwasher, any of those other options are asking for trouble and you could quite likely be looking at loosing your deposit +more to repair the damage.
It is plumbing under the sink and the inlet for washing machine
If you swap the washing machine speedfit valve, for a Tee, you could then have two washing machine valves coming off the Tee, that would give you the two cold water supplies you are looking for. Might be one to get a plumber out for if you're not comfortable working with these, would be a pretty quick job for a professional.
If this will work
https://www.NoLinkingToThis/p/washi...2CZX8ojj3TrJKuk1AAYFP34xGUlv0YsUaAgh-EALw_wcB
Yeah but not ideal as they're pretty flimsy and you can't isolate the appliances individually, there's a brass version with an isolator on each connection that would be better. I think screwfix do them, more expensive but much better, or as also mentioned above, use a tee then 2 separate appliance taps.
The pipework under there looks totally unclipped/unsupported, you'd need to sort that out before changing anything under there or the landlord would blame you if something blew off and flooded the house.
Thinking about it, to be covered you'd need a competent, insured person (i.e. a plumber) to carry out the work with your landlords written permission. If you did it yourself and something went wrong you'd be 100% liable for all the damage.
Reply to the thread, titled "Hello all - please help - dishwasher inlet into sink tap" which is posted in The Welcome Wagon :) on Plumbers Forums.
Kiko,
JCplumb,
