Guest viewing limit reached
Hello all!
View the thread, titled "Hello all!" which is posted in The Welcome Wagon :) on UK Plumbers Forums.
C
charitynjw
Hi everyone!
Just testing
(Tried to post a minute ago, but computer said no! 🙁)
Welcome to Plumbing Forum | Plumbing Advice | Plumbers Forums | A forum for plumbers advice in the UK!
Hi charitynjw and welcome to UKPlumbersForums.co.uk!
Yeeesss! - Up & running!!
I stumbled across you guys (& girls?) while searching on-line for a good 'A'-rated wall-mounted b/f blr to replace an existing Thorn M f/s (approx 20kW). Minimal resiting, & drainage (condensate) not a problem. Existing o/v S-plan.
Probably eligible for scrappage scheme, & having been in the industry (but out of the loop for a couple of years), I would prefer value for money & reliability over 'cheap'.
Any advice would be appreciated.
you cant buy a bf condenser,they are all ff now,baxi duo tec,platinum,potterton gold all good boilers the plat costs more than the duo tec because it has a 5 year warrenty but same boiler as duo and gold but they are all pressurised system boilers do work better though
Hi Mark,
Thanks for your reply.
I should have said room-sealed (I was around when b/f appliances first came out - old habits die hard lol).
I'm a bit wary of fitting an unvented boiler as the existing pipework/rads are ancient as well, but are ok on open-vented. (I don't relish the thought of having to sort out a million little leaks!)
I've heard good words about Rehema? blrs - any thoughts?
As before, all advice gratefully received
Reply to the thread, titled "Hello all!" which is posted in The Welcome Wagon :) on Plumbers Forums.
charitynjw,
charitynjw,
