V
Vessy
Hi all, this site has helped me out many times, i've tried a search but getting nothing specific to this question.
Just moved into a 1970's property, which is still in the 1970's!! after failing to successfully balance the radiators I thought I had better investigate the system to see where the problem lies, this revealed a one pipe (or single) pipe radiator system, comprising of two loops, upstairs and down, the system has been re-worked previously to a fully pumped system, removing the gravity fed HW circuit.
I have concerns as to the boiler vent and header tank feed pipework, they are connected to the primary coil pipes at the cylinder (vent tee'd into flow and feed into return)
I think I need to run the pump on setting 3 to push the water quicker round the radiator loops as the furthest radiator is dropping a massive 50 Deg F with both valves fully open, however when I do this i think i'm pumping over as the header tank was steaming hot.
I'm also concerned that the vent pipe is sealed off by the HW Valve when just radiators are being supplied.
I have attached a sketch of how it's plumbed, Pump and valves are located downstairs next to the floor standing boiler, HW cylinder upstairs with Tees to header tank pipework.
Is there a way to improve the system? is my concern about the vent closed off valid?
Many thanks.
Many thanks.
