O
olfrog
Hi peeps,
I bought this concealed triple shower/bath valve about 9 months ago: S9 Triple Concealed Shower Valve with Square Plate
I had to turn the combi boiler off for a week whilst i installed new radiators in the flat. When i turned the boiler back on after a week, the valve seems to have gone weird. Basically, the cold water flow is eliminating the hot water flow - i.e. the cold water pressure is so much higher so hot water cannot get through. The only way i can run a bath or shower is to turn the cold water off using the service valve.
Despite this, all the mixer taps in the flat work fine (i.e. the cold water pressure does not prevent hot water coming through). So it must be a problem with this, rather than with the hot pressure?
I'm on a direct system, and I've attached a photo of the back of the valve (when i was fitting so some of the pipes are missing).
Is there something wrong with the thermostatic part? On this one, there is no dial etc, like i have seen on more expensive thermostatic valves (indeed i did wonder whether this actually is one!)
Thanks a real lot for any suggestions you may have!
Ol
Ol
