View the thread, titled "Help! Bristan shower cartridge , cant turn off cold water from shower" which is posted in Showers and Wetrooms Advice on UK Plumbers Forums.
Can anyone help please ?
I am in the middle of trying to clean/ service a Bristan shower cartridge for this shower
Recessed concealed shower
1901 Concealed Concentric Shower Valve | Bristan - https://www.bristan.com/products/mixer-showers?code=n2%20cshcvo%20c
It had started to drip after Thames Water installed a water meter outside . I was advised to clean the cartridge .
This morning I started to try and dismantle it to access the cartridge ,and as I started to do this the cold water started to run through the shower more and so I turned the water off . I got so far and could not remove the cartridge as the instructions are not clear and I cant find it on youtube. I am down to the level in the photos, I cant twist or pull the cartridge out . Am I supposed to remove the small plate surrounding the cartridge by removing the circular discs and parts either side of the cartridge ? Not sure how to do this .....I thought the cartridge would pull straight out when I got to this level
I reassembled it without moving the cartridge but when i turn the water on I cannot stop the cold water at all through the shower heads , when i turn the valve it just wont turn off
Please help , its now driving me mad ! thanks
Betty
there was nothing wrong with it before!, it only started dripping after Thames Water dug up the road and installed meters ! I was left with two dripping showers ! now this carry on... because Bristan sent wrong instructions and sent me off on wild goose chase " oh you can just clean it taking out cartridge and by soaking in water and vinegar ..." Need a large drink and lie down!
Yep common for them to get grit / other things in your water main when working on it which f ups ball valves and showers
Reply to the thread, titled "Help! Bristan shower cartridge , cant turn off cold water from shower" which is posted in Showers and Wetrooms Advice on Plumbers Forums.
Thread starter
Joined
Thread Information
Title
Prefix
N/A
Forum
Start date
Last reply date
Unsolved
Thread Tags
Bettyboo,
ShaunCorbs,
