djkay1982
I plan on installing an 1800x800 double ended hydro therapy bath into here
this is the bath I plan on installing
Buy Hydrotherapy Kube Bath 80 in Hydrotherapy Baths at Victoria Plumb
as you can see with it being double ended, The taps are not on the end, they are centred (though Im not going for taps, I plan on fitting a flush filler valve)
and on the opposite side is the controls for the whirlpool/Airspa
I am installing a Consealed triple thermo valve to control bath & shower (this will be installed in the same place as the exisiting shower.
my question is, is this possible/feisable? from and installation and maintenance point of view?
as once the bath is installed the only access will be from the side panel
im not sure how it all connects at the moment but planned on using the existing bath hot/cold feed to run to the whirpool/airpa controls
then the exisiting shower hot/cold feeds to the consealed thermo valve (chased into walls, as at the moment they are exposed) then from thermo valve down to the bath filler valve.
how am i best doing this?
thanks lads, hope you can point me in the right direction
