A
My son accidently turned the boiler on while we removed the out cover. The two wires to the fan motor are damaged and got short circuit by fire. The in-line fuse gone. After I separated the two wires and replaced the fuse, the boiler does not work. According to the Menu, there should be either 1V or 10V(DC) at terminal 1. However, no voltage reading. At terminal 10, reading is 230v (AC)
Thanks for your help.
Thanks for all replies. I am an electrician. I fully understand the importance of safety. I never touch the gas parts. Due to some reasons, I opened the cover.
I think I can easily change a PC board if faulty. That's why I post this.
OK. We are in an issue with someone in another country (The boiler is not in UK). I opened the cover under instruction from a UK plumber to take some photos.
Anyway, my son has already got a lesson.
I am trying to get help from all of you because I called some local plumbers and they want to charge us 400 for a PC board. You know the cost for a board is around 100 in the UK. This is the reason why I am trying to sort out the problem if it is a board problem. I am still calling more plumbers to see if I can get a reasonable price.
Thanks again to everybody.
Looks very clean inside ! Has this boiler been used ?
Reply to the thread, titled "Help for Halstead Best 60 boiler" which is posted in Boiler Advice Forum on Plumbers Forums.
