T
tiny
Hi Folks could you please give me some advice what Heating Controls I should fit to the following System
I am converting 2 adjacent Houses into 1 and I am upgrade the Heating System to supply 2 Bathrooms and 4 En-Suits along with a total radiator load of 100,000BTU all to be fed from a single 40KW LPG System Boiler, feeding an unvented 300ltr 3 coil water tank. The tank could also be heated from a Back Boiler, with a spare coil so a Solar System could be added at a later stage, it would also have a standard 3KW Imersion Heater fitted. I was hoping to have the finished Heating System split into 4 zones controlled from multi Zone Programmer. I was hoping to use as many Wireless Products as possible but I don’t know if they would suit our System because the premises is split in 2, one old section (Ground,First, and Second Floor`s) with thick stone walls the other new (Ground and First Floor) built with standard Block walls. Another complicating factor is we have Wireless Smoke Detector/Alarm Units in use throughout both buildings, along with Microwave Ovens in use in the Kitchen, and 1 set of 5 cordless Phones.
As I said I was hoping to have the System split into 4 Zones
Zone 1 New Building section for Downstairs Heating to be controlled by up to 2 Stats
Zone 2 New Building section for Upstairs Heating to be controlled by up to 2 Stats.
Zone 3 Old Building section (The Complicated one) to be controlled by 5 Stats that also control the individual Radiators (1 in each room) in the Rooms where the stats are placed in.
Zone 4 Domestic Hot Water Heated by the Gas Boiler or 3KW Electric Water Heater if Switched on and the Gas was off.
The Rooms in Zone 3 (the older Building) are located about 20/25 Metres away from the Control Programmer, all other Stats, Boiler Controls and Hot Water Tank would be about 5 Metres from the Programmer. If it was more convenience Zone 3 could be treated as a separate wireless Zone and any Control Signals could be hard wired back to the central Programmer.
Tiny
Tiny
