Help needed with kitchen sink overflow
View the thread, titled "Help needed with kitchen sink overflow" which is posted in UK Plumbers Forums on UK Plumbers Forums.
K
koivunenr
Hi
I have a problem with a kitchen sink recently fitted. I have noticed water running through to the cabinet below. When I've looked closer I can see it is because there is no pipe connecting the overflow vent to the main waste pipe. The overflow is on the sink drainer near to the basin and has the plug chain attached. When I contacted the kitchen fitter he told me that it doesn't need a pipe and that it needs a 'blank' fitting to cover the hole. I can't believe that this is right? He isn't very forthcoming with where I can get this blank so I am left with a sink with a hole in the top.
I am not technical in any way so I don't know the name of the pipe or if I'm right that there should be a pipe connection. Any help or advice would be really appreciated.
Rachel
overflow, is what its called
used when water is overflowing to go down the drain instead of the floor.
pics would help, we may be able to tell you how to sort it, or what to get to sort it
Reply to the thread, titled "Help needed with kitchen sink overflow" which is posted in UK Plumbers Forums on Plumbers Forums.
koivunenr,
koivunenr,
