View the thread, titled "Help..New pump fitted, not pumping?" which is posted in UK Plumbers Forums on UK Plumbers Forums.
bob-the-wrecker
Hello,need a bit of help here please. Mother in laws house had lay empty for a while and the roof of the shed where the boiler was had fell in. Every thing was soaked. New roof fitted and every thing dryed out so we turned the heating on...started up ok for a few minutes then knocked the power off. Turned out the pump was soaked and had died so fitted a new pump there today and started the boiler, away it went and the pump was spinning away but it didnt seem to be heating the radiators the after 15mins the boiler turned off (it was really warm) so whats up? Could the pipes be blocked? Or is it possible the pump is working back to front? The arrow is pointing the same way as the old one was? Thanks...Owen
is the pump circulating the water or is it air locked
has the system got enough water in ?
have you bled any of the system ?
Reply to the thread, titled "Help..New pump fitted, not pumping?" which is posted in UK Plumbers Forums on Plumbers Forums.
