Help Please, Salamander Accubust Water Pump
View the thread, titled "Help Please, Salamander Accubust Water Pump" which is posted in UK Plumbers Forums on UK Plumbers Forums.
Help pls, I’ve got a Salamander Accubust water main pump it has an in & out & third port for an accumulator can I blank off the accumulator port & use it as a mains water pump without an accumulator? TIA
I would give Salamander technical guys a call on Monday to check. However my understanding is that the pump is designed to recharge the accumulator and also offer a mains boost of 12lpm once the accumulator has been discharged. So in theory yes it would work but 12lpm is still quite low on a system and I would consider other options if your mains is already below this.
Reply to the thread, titled "Help Please, Salamander Accubust Water Pump" which is posted in UK Plumbers Forums on Plumbers Forums.
Zoe100,
ShaunCorbs,
