View the thread, titled "help. removed a radiator now i have no heating or hot water." which is posted in Bathroom Advice on UK Plumbers Forums.
shaunbell
hi i am new to this site and would like some help if possible.
today i removed a radiator from my dining room so i could wallpaper behind it. all i did was remove the rad from the valves just draining the rad and not the full system. both valves are closed but now my heating has gone off and i have no hot water. please help.
hi steve, its a combi in the loft. a baxi duo tec. is there any thing i can do to fix the problem. decorators not coming till saturday. thanks
hi , thanks for your quick reply. if i increase the pressure on the boiler to 2 bar would that fix things or would i have to put rad back on. cheers
look by the boiler you will have a silver, flexible braided loop open the valve connected to it,look at the pressure gauge on the boiler,pressure to 1.5 bar,turn the valve off it should then work
thankyou for your help gas man. will i have to put rad back on wall first or can i just re-pressure the system. will this fix my heating and hot water. my decorater is not coming till saturday. thanks
if you have a trv on the rad it may pass water either put your rad back, and re-pressurise and fill it back up or get a cap to fit on the trv(1/2 inch female) or re-pressurise with someone watching the trv see if it passes if so turn thee filling loop off and go back to step 1
Just top system back up with radiator off, check valves are not passing water. Don't go above 1.5 in my opinion. Duotec has built in bypass but would be better if one of your radiators in house had no thermostatic valve on just in case.
yes it has a trv on rad, i dont think it was leaking when i removed it. will this still have caused the pressure to drop and boiler to cut out. as for caps to fit the trv's would a compression coupler female cp do the job item 93355 in toolstation catalogue. thanks
Reply to the thread, titled "help. removed a radiator now i have no heating or hot water." which is posted in Bathroom Advice on Plumbers Forums.
