H
Hillclimber
I recently purchased a preowned Holiday house fitted with the above boiler for hot water & heating.
To move the unit (Its weighs 11 ton!) I had to disconnect the gas supply (two 300psi cone seat unions) from the 2 x47kg LPG bottles plus the pressure regulators to prevent damage during transit and then reconnect when the unit was in place.
I called a Gas qualified engineer to re-commission the boiler and issue a landlords certificate.
He refused to do this since I, a non qualified engineer, had touched the pipework.
I need a qualified engineer who would undertake the recommissioning, even if he needs to disconnect & reconnect the unions and regulators ??????
I live in Long Stratton area (Nr.Norwich) and need urgent help since 1st tenants arrive soon.
tbh the poster is in the wrong and the gas engineer has followed the regs as who is to know who's done what before he arrived on scene. A sensible owner would have got the techie to disconnect prior to move then reconnect the lot on completion of the move. Last two lpg systems I have been too both got IDed, and then re supplied with bottles moved, boiler reconnected correctly and recommissioned. Could be the lad who turned up didnt like what he saw and ran away, doesnt make him a douchebag imho, just careful of his bum.
Reactions: 2 people
Thanks for the comments, I am the original poster of this.
I am a 70 YO engineer who has, since retirement built and raced two single seat race cars, converting one of these from carb to fuel injection using 3 bar methanol fuel pressure and a programmable ECU. I was trained as a refrigeration engineer (Ammonia) at 20 bar and I find it incredulous that these proven skills are not accepted in a 1 bar or less LPG environment. The "Qualified" Gas engineer who visited did not even realise that the high tech pressure regulators (1 bar to 37mbar) could be manually adjusted for correct downstream pressure or that soldered copper pipes could be used for low pressure distribution.
What is the UK coming to?? or is it a matter of being able to tick box's - again.
You could be qualified to build the space shuttle. Doesn't mean you're competent or qualified to work on gas. The law is very clearly defined on this matter. It's far from being a box ticking exercise.
And yes, regulator pressure can, theoretically, be adjusted. This would be sticking a plaster over another issue you may or may not realise you have.
Reactions: 5 people
Yes but can I see your gas safe card.
In a previous life I worked on jet engine parts from rolls royce and also developmental parts for the new XWB boeing.
However I cannot fly a plane
Reactions: 3 people
I still think the original engineer could have been a little more understanding and inspected the regulator and unions but, you know, maybe i am too soft...
Dont think he can otherwise he would.
Holiday parks normally need to see paperwork for their insurance from caravan owners ??
I'm qualified to service and repair diving equipment and cylinders ,used to 300 bar I'm also gas safe qualified for natural gas, that doesn't mean I'm competent on LPG and neither are you. This is a job for an LPG engineer best leave it to the experts
Reactions: 3 people
nothing worse than someone warbling in your ear about this n that, probably why he left.
Strongly recommend that the op now reads the forum rules and the Gas Safety (Installation and Use) Regulations 1998.
The op probably gets the point now however.
Thread closed.
