View the thread, titled "Help - Vokera Compact Boiler Temporary fault" which is posted in Boiler Advice Forum on UK Plumbers Forums.
T
timmsy
Can anyone help? My Vokera Compact Boiler flares up with the pilot light green but after approx 5 minutes you can hear it 'firing down' and the pilot flashes green every 0.5 seconds (which says is a temporary fault). This lasts for approx 5 minutes then the boiler fires up again and the light solid green. This cycle just repeats itself with the boiler continuosuly firing up and down. I have checked the pressure which is fine. The radiators feel as though they need bleeding do you think this may be the problem or has anyone any ideas?
Thanks for any help.
We cannot and will not give advice on the installation or repair of boilers, cookers or ANY gas appliances for your own safety.
Please go to Gas Safe Register | Ensure your gas engineer is registered. or post a thread in the 'I'm looking for a plumber / gas engineer' section of these forums remembering to include your location. [DLMURL="http://www.ukplumbersforums.co.uk/im-looking-plumber-gas-engineer/"]I'm looking for a Plumber or Gas Engineer[/DLMURL]
If you are gsr please increase your post count to 10+ then send a PM (Private Message) with your gsr details to either Gas man - View Profile: gas man - Plumbing Forum | Plumbing Advice | Plumbers Forums | A forum for plumbers advice in the UK or Redsaw - View Profile: REDSAW - Plumbing Forum | Plumbing Advice | Plumbers Forums | A forum for plumbers advice in the UK who will check you and then give you access to the gsr private forum.
Providing gas-related advice to anybody who should not be touching gas and cannot prove their competence is unacceptable. We will take whatever action we deem appropriate to prevent such advice being given
Thank you.
UKPF TA's, Mods and Admin teams.
http://www.ukplumbersforums.co.uk/central-heating-forum/42241-notice-gas-safety-related-advice.html
Reply to the thread, titled "Help - Vokera Compact Boiler Temporary fault" which is posted in Boiler Advice Forum on Plumbers Forums.
