Help!
View the thread, titled "Help!" which is posted in UK Plumbers Forums on UK Plumbers Forums.
B
big al
Helped my neighbour replace an old single rad(approx 30yrs old) for a new double rad, had to alter old pipework to fit new valves. So drained down the sysyem, altered pipe to suit new rad refilled the system and bled the rads. Switched on heating all come on fine and went off ok, but when the water gets heated the rads upstairs come on???????
What is the cause and how do i fix it please.😕
not too sure on the type of system, cant find a diverter valve in the airing cupboard, and it never used to do it before
if its a gravity hw, pumped heating system.
sounds like the gravity check valve is stuck open.
finally got round to changing the gravity check valve, but the rads still come on upstairs when the hot water heats up....????
Reply to the thread, titled "Help!" which is posted in UK Plumbers Forums on Plumbers Forums.
big al,
big al,
