DirksPlumbing
Seen the LLH installation, looks marvelous. But I am not a big friend of them as they decrease the system efficiency by artificially lifting the return temperature and therefore decreasing the condensation effect.This is why with these big boys (boilers) it is better to install a low loss header.
CW
Better is controlled zoning. Honewell does some nice valves to ensure that the zones are getting what they are due. You can then ABV each zone individually to use the pipework as buffer for the boiler output.
(Add: saves adding pumps using electric power)
The 15/60 would struggle on heavy use of microbore already with less than 20kW.
