High pitch noise from boiler flue
View the thread, titled "High pitch noise from boiler flue" which is posted in Boiler Advice Forum on UK Plumbers Forums.
My boiler has started making a very high pitch noise when the heating turns on.
It seems to be originating from the boiler flue (see video https://bit.ly/3pYMFrI )
Is this an indication of air trapped in the system ? Do radiators need bleeding ?
Or a sign of faulty boiler part ?
Would say needs a gas engineer to have a look might just need servicing but might need two parts replacing
Probably to do with the combustion and needs an engineer.
Unlikely to be dangerous but would get it looked at as soon as reasonably practicable (I hate that term).
As above, needs someone familiar with Ideal Logics to give it a full service - removing the burner and flushing it through. If that doesnt help will need a part or 2 to get it back to normal
Reply to the thread, titled "High pitch noise from boiler flue" which is posted in Boiler Advice Forum on Plumbers Forums.
Rajen,
Scott_D,
