Hints, tips & secrets of plumbing - No Banter please!
View the thread, titled "Hints, tips & secrets of plumbing - No Banter please!" which is posted in UK Plumbers Forums on UK Plumbers Forums.
Clean up after you've finished a job, even if the lady or gent of the house says it's fine.!!!
Check that all controls etc. are working before you start a job so that you don't get stitched up when they don't work afterwards.
Different Models Of Listening Sticks By Vernon Morris At Reasonable Price.. you only need the 8" one. better than sticking a screwdriver to your ear which ive seen done. can get extensions as well for checking for mains leaks..
I've got one of these from Machine Mart.
Clarke CHT171 Mechanics Stethoscope - Machine Mart
Cheap and does the job.
Those of us of a certain age will remember from early childhood that to get milk from a tin it is necessary to make two holes so air gets in as milk comes out. Working on closed heating systems, once pressure is released, this principle has numerous applications:- Radiators can be drained by fixing hose to remote drain off and then opening air vent at radiator, Rad valves can be changed one at a time without drain down, inhibitor can be added by siphon and the replacement of air faulty air valves etc. is a doddle.
When called to deal with blocked sink always replace the bottle trap. The client will perceive more value in the replacement than the one minute it takes to clean the existing and the husband will not be embarrassed for not having done it himself.
Are you suggesting that the bottle trap should be replaced with another bottle or replaced with a tubular trap, because the sink is blocked ?
Not commenting on merits of traps but on clients perception of value. People who would not get out of bed for less than £500.00 per day begrudge paying us half that sum to cover our costs and wages. Won't even comment on pensions and holidays.
probs been covered before but when fitting for customers who know your job 10 times over mark the fittings with illumines pens the ones the require blue light to see then you can see that they have taken the trap off and put it back on and then for some strange reason its threaded and leaking just saved a bit of agro!
McAlpine make a 20mm plastic compression union, keep a few on the van. These are invaluable for repairs to overflow or condensate pipes as they will take the slightly bigger and slightly smaller variants of pipe.
A temporary fix for a faulty expansion vessel: drain and refill the system and bleed all radiators except 1 this radiator will act as a temporary expansion vessel
And it will work even better if you stop the flow through this radiator - i.e. close one (and only one) of the two valves
I've used 22mm speedfit before now🙂
For IKEA waste pipe fittings.
If the pipe provided is smaller diameter than the UK pipe, soften the end with a blowtorch and push ontor something cylindrical of a large enough diameter which has been greased, to stretch it.
When fitting solvent or push fit pipes make sure any lettering is faced away from the eye
Did a customer pull you on that Lee :lol:
We have all done it at some point but it looks bad.
Btw cast iron should always have the stamp facing forward for any numpties that follow to identify it.
Following on from WHPES you can make a socket on any size solvent plastic pipe by gentle use of the blow lamp. Use this method for joining dissimilar overflow and waste or if you are ever short of a union even on 4".
The trick is learning how to get it to look good and even all round :wink:
No tamz I probably have like but I've seen it on 3 repairs this week long runs and it wound me up
I never used to bother too much until i got pulled up on it years ago and had to change the pipe. Not a big deal for 4ft of pipe and a couple of fittings but it made me aware of it ever since and now it does my nut in too :smile:
What was the problem ?
I'm sure it must of been posted but I'm not reading 761 posts to find out! Here goes, make sure the kettles full before turning the water off!!
Write all over your power tool batterys or wrap them in insulation tape. Stops others on the site swapping their deads with your lovely working ones!
Feins and other multi tools (i have a milwaukee) can save you the headaches of cutting joists with no access or copper that you cant even get a junior hacksaw too!!
invest in a decent multimeter and learn how to use it, its a great help and could potentially save your life!
Reply to the thread, titled "Hints, tips & secrets of plumbing - No Banter please!" which is posted in UK Plumbers Forums on Plumbers Forums.
REDSAW,
firemant,
