Deleted member 118509
Afternoon all,
bit of a long-shot.
My brother in-law is an electrician.
I’m and average DIY-er.
we’ve installed a Hive Thermostat onto my boiler, which is a Ferroli Domicompact F30.
everything is wired in:
  • hub connected to router/internet
  • receiver connected to power & boiler
  • thermostat connected to both.
when we turn the heat up, the receiver clicks and green light illuminates. As such, it appears the request to turn up the heat is being received.
However, the boiler doesn’t initiate and heating does not come on.
we’re thinking it’s something to do with the old clock/timer that’s already wired into the boiler. This is switched to ‘on’ permanently, as opposed to ‘auto’ or ‘off’.
Any ideas if anything needs changing?
my brother in-law fitted exactly the same on his baxi boiler and it worked perfectly.
Responses in bold above 😉 hopefully your new bloke will sort it.
Ok so it's working now and seems like I was wrong.
Seems like it was needing to be on 1&3 also with the settings on the boiler as per images below 20211002_190131.jpg
