L
lame plumber
finally cabin fever set in and I sneaked out to service a firebird 26c. Baffle door insulation burnt out!, baffles clogged up and back to front, wrong nozzle, flexi hose never been changed and filter !!!!, couldnt believe it was firing when I saw the photocell which was sooted over completely. Anyway, replaced the leaking condensate drain off and cleaned and set it up, all packed up and saw the oso uv cyl prv was passing, drain off to restore airgap was seized, so a bit of a fight to retrieve the washer and sort it out. got to pop back to replace the door insulation panel and check the prv. An easy number turned into a bit of a nightmare but happy to report knee hobbling around ok to date🙂🙂🙂🙂 only out 4 hours, so caught out by missus as I snuck in.
