Honeywell cm907 room thermostat.
View the thread, titled "Honeywell cm907 room thermostat." which is posted in UK Plumbers Forums on UK Plumbers Forums.
We live in a 2 bedroom detached bungalow with a Vaillant Eco Tec Pro 28 combi and a Honeywell cm907 two wire thermostat. The whole installation is 5 years old, and now the lcd display on the stat is loosing pixels. Having looked on the internet I can see this is a common problem and there are bodge fixes but I doubt any will provide a permanent solution. For about £70 I can buy an identical replacement which I can install without even touching the wiring (just swap faceplates) ,but here is the dilemma:- the Honeywell is quite a clever programmer with temperature settings variable by the hour and day of the week + other clever stuff, however I just switched it to manual 5 years ago (so it's active 24/7) and the wife and I adjust the settings as required (she turns it up,I turn it down). For around £20 I can buy a non-programmable two wire thermostat which should provide the control we need and save us OAPs £50 .
Is there any problem with the cheap option? WCPGW.
Thanks.
Not many issues at all.
Just find out the voltage that is operating the system thermostat - either 240 volts, 24 volts or 12 volts.
If it's 24 volts or less you can use any thermostat you wish.
If it's 240 volts you will have to find something that is suitable - less choice.
If you decide to change it for a simple room stat and just leave the heating on 24/7 and the room stat controls when the boiler heats, you need a digital room stat as you don't have a neutral connection at the stat (just live in live out)
So you can't just go for a stnd mechanical room stat like the 6360b as these need a neutral connection to be accurate if you don't use a neutral on these stats there accuracy is about + or - 5dc
If you would like something similar to the one that you have already. Try this one. Cheap and cheerful and made by Honeywell and aparently no display problems.
thats the wireless version mate hes got the wired one
Sorry mate one of the kids woke up before I had finished what I was doing. Must have clicked post by accident. Was going to say if you can stretch to it have one of these. I also have started to fit draytons
😀 everything ok?
Reply to the thread, titled "Honeywell cm907 room thermostat." which is posted in UK Plumbers Forums on Plumbers Forums.
RayW,
Harvest Fields,
