boiler10
Hi everyone, just need a bit of help please. I have an ideal logic boiler with a Honeywell CM921 room stat and I seem to be having a few problems.
I will try to explain exactly what happened today. Has happened quite a few times before.
Turned the boiler on using the Room Stat with target temp at 19 C.
House started to get really hot. Checked temperature on stat and it was well above the target temp.
Checked the boiler and the Central Heating was still running with a "C" in the display.
Took the stat upstairs, turned it on and off several times, wouldn't work. Bolier still kept on running, despite trying to turn it off using the stat.
Then, had to turn the boiler off manually using the controls on the boiler.
When the boiler was turned back on, the Room Stat & Boiler were communicating again.
Any ideas plse?
Thanks 🙂
Any ideas plse?
Thanks 🙂
