Honeywell normally open zone valve
View the thread, titled "Honeywell normally open zone valve" which is posted in UK Plumbers Forums on UK Plumbers Forums.
Interesting question and one I’ve never even thought about until I messed up today. This might be a bit long….
I’ve got a multi fuel system on the go, gravity primary’s for hot water off Rayburn, big biomass boiler, air source is involved for the floors , pumped heating split into 5 zones blah blah blah
So I’ve got 10 zone valves in total, it’s a pretty complicated system but nothing too crazy. However I messed up massively today. I fitted the wrong zone valve In the wrong place. I should’ve put a normally open valve in off the hot water (gravity) but I fitted a normally closed one instead and the normally open is elsewhere.
Can I just swap the heads over? Does anyone know?
Are the body’s the same ? Surely it’s just a reversed actuator motor right?
Can I just swap the power heads over instead of having to drain this behemoth down. It was an absolute pig to fill up
I’m hoping someone just gonna say , swap the heads the body’s are the same
Cheers
Reply to the thread, titled "Honeywell normally open zone valve" which is posted in UK Plumbers Forums on Plumbers Forums.
Traditionalplumber,
Traditionalplumber,
