View the thread, titled "Hot air system" which is posted in Air Sourced Heat Pumps Advice Forum on UK Plumbers Forums.
T
TCPS
Hi there,
just wondered weather anyone can help me out, is it a possible to have radiators added on to a hot air system?? There is a cylinder with a flow and return for the hot water. Is it possible??
A towel rail at most and it would need to be a brass or copper one (chromed). It would also have to work on gravity. The HW circulator side is direct so if you add anything steel to it it will rust = rusty water at your hot tap (won't impress the wife when the washing comes out orange) and cannot be pumped.
Why would you want rads when you already have warm air? The ducting could be altered to lead to different rooms but it is not a job for diy. These appliances are lethal if they are done wrong. No second chances.:skull:
Reply to the thread, titled "Hot air system" which is posted in Air Sourced Heat Pumps Advice Forum on Plumbers Forums.
