Hot flow and return pipes, hot upstairs rad but cold rads downstairs
View the thread, titled "Hot flow and return pipes, hot upstairs rad but cold rads downstairs" which is posted in Air Sourced Heat Pumps Advice Forum on UK Plumbers Forums.
As in the title, the flow and return pipes both get hot when the heating is turned on, yet only the upstairs radiators get hot.
I am very puzzled by this. Even turning off all thermostatic valves upstairs, none of the downstairs rads get hot. Our plumber says there must be a blockage looking for a second opinion. Not sure how there can be a blockage if the return is still hot.
Any help would be appreciated.
Mark
I see, it still just seems strange how it cuts off at heating all radiators upstairs perfectly but none of the downstairs ones at all, they arent even luke warm. They are ice cold yet the return pipe to the boiler is super hot.
I cannot say any more. Really sorry mate. Your engineer should know what to look at on the boiler.
I am hoping that is the case, shelled out a lot of money for it and don't want to spend even more on additional work!
easy way to tell if its blocked but requires removal of a rad
remove a rad and test if you have water coming out of each valve from the rad you removed if you have its not blocked
All goes into the mixer mate. Always worth pointing out.
Most of the new valiant boilers you can on the boiler Display give so many KW to heating and hot water just check this . if the heating has not been used in summer most times the pump gets stuck free this up with big screwdriver I have also seen the nut behind the chrome screw on pump turn but the impeller stays put? As with Most of the new Boilers Valiant. Glow- worm. Worchester 30 CDI you can Map the Pump you should look at this as well . I think you should be ok if you are only touching the wet side of system To put it another way if AAV went in boiler and water flooding every were and in order to stop this you could turn off isolation valves I know what I would do
Not a gas engineer myself mate so think I will leave the internals alone as advised but thanks anyway.
Right, the problem is solved!
We had a gas engineer over for about 45 minutes trying various things. He put the boiler into service mode and closed all upstairs rads. Nothing got hot downstairs. He recommended a power flush.
Few days later a different engineer from the same company called me about the power flush and suggested it may be an air lock. He suggested there may be an air release valve somewhere upstairs but I didn't know where it could be.
He came over, had a look at our pipework. Mentioned an airlock is very likely as it goes up and over so is quite prone to that happening.
Put the boiler into service mode again and whacked the pressure right up and turned the pump up (was on auto before). This fixed it, suddenly heard all the air moving in the system and voila, heat downstairs. Shouldn't happen so easily now either.
Very pleased as saved a £500 power flush which wasn't even needed!
Awesome news mate. Glad it is sorted and you saved money. It’s nice to get feed back, it doesn’t happen often. As you saved £££s I hope that you gave him a drink?😉😉😉😉
Reply to the thread, titled "Hot flow and return pipes, hot upstairs rad but cold rads downstairs" which is posted in Air Sourced Heat Pumps Advice Forum on Plumbers Forums.
Mark Garland,
Mark Garland,
