View the thread, titled "Hot flow and return pipes, hot upstairs rad but cold rads downstairs" which is posted in Air Sourced Heat Pumps Advice Forum on UK Plumbers Forums.
As in the title, the flow and return pipes both get hot when the heating is turned on, yet only the upstairs radiators get hot.
I am very puzzled by this. Even turning off all thermostatic valves upstairs, none of the downstairs rads get hot. Our plumber says there must be a blockage looking for a second opinion. Not sure how there can be a blockage if the return is still hot.
Any help would be appreciated.
Mark
No worries, it's just the boiler has a warranty but I don't want our plumber to try and go around it by blaming the problem on our pipes.
We haven't got much experience with them so still building up trust so don't want to be given the run around hence asking on here.
Your first point of call should always be your gas engineer. But if you have lost faith then go straight to Vaillant. They are generally really helpful and if you have warranty they will come out and have a look.
if it shoots up and doesnt go down within 2-3 mins and boiler doesnt stay lit (fired) then i would say pump could be stuck
Right, just tried again. After turning the thermostat up, temp rose very quickly to 57, then dropped back down to 50 (sounded like pump turned on), then was fluctuating from 55-50 after 1 minute.
After 3 minutes its 57
4 minutes its 59
5 mins its 62 (boiler still fired)
7 mins in its 66
So, does seem to be rising slowly.
I am heating a click sound every so often (every 10-30 seconds) not sure if that is important.
I see, it still just seems strange how it cuts off at heating all radiators upstairs perfectly but none of the downstairs ones at all, they arent even luke warm. They are ice cold yet the return pipe to the boiler is super hot.
I cannot say any more. Really sorry mate. Your engineer should know what to look at on the boiler.
I am hoping that is the case, shelled out a lot of money for it and don't want to spend even more on additional work!
easy way to tell if its blocked but requires removal of a rad
remove a rad and test if you have water coming out of each valve from the rad you removed if you have its not blocked
Reply to the thread, titled "Hot flow and return pipes, hot upstairs rad but cold rads downstairs" which is posted in Air Sourced Heat Pumps Advice Forum on Plumbers Forums.
