Hot water advice please
View the thread, titled "Hot water advice please" which is posted in Bathroom Advice on UK Plumbers Forums.
rocketmanbkk
Hi Friends
Fitted new kitchen mixer earlier, all simple as ballofix on hot & cold (makes a change).
The hot ballofix is weeping.
Vented system, the hot has a gate valve under the sink but it's seized.
No other valves on hot.
So, shall I just turn cold feed to hwsc (in place & turns) & run hot taps until water ceases? I can then change both ballofix & gate valve at the same time.
Is this ok to do? Again it's the air lock anxiety issue!!!
Cheers
Rct
Ah by implosion do you mean that the water pours out of the open pipe?
or collapse of the hot water cylinder itself? Just wanted to know what terminology you mean
russ
What can happen if you bung the vent
Reply to the thread, titled "Hot water advice please" which is posted in Bathroom Advice on Plumbers Forums.
rocketmanbkk,
rocketmanbkk,
