Hi all,
Sure this has been answered many times but can't quite see previous post which covers this. I'm not a plumber which will likely become obvious! 😀
So, currently suffering from constant run-off from F&E overflow into garden - moderate flow, like a tap is on!
The F&E tank is filling up due to back flow from the gravity pipe out of the tank (aka reverse flow). Just to confirm the tank is not filling up via the mains feed/ball valve and not through expansion via the vent pipe. It's back flowing with warm/hot water back up the outlet.
I confirmed this by tying off the ball valve and emptying the tank, I can see the water returning into the tank once emptied from the bottom of the inside of the tank.
It does this whether or not the boiler is on or off.
I'm of a mind to think it's either a compromised coil in the hot water cylinder or a problem with the mixer shower. I'm going to isolate the mixer tomorrow just to see if the problem does stop.
If it's not the mixer I'm of a mind to replace the cylinder but am I on the right track or barking up the wrong tree! Is there anything else which could cause this? I don't want to replace the cylinder uneccessarily.
Many thanks in advance
Dar
Dar
