Hot water cylinder leaking
View the thread, titled "Hot water cylinder leaking" which is posted in Bathroom Advice on UK Plumbers Forums.
bogman
Hi Guys, Bogman here. I'm new to the forum and would appreciate a bit of advice regarding my Hot Water cylinder which has started leaking from the bottom underside. It is an Ariston Contract STI 210 Indirect with an Immersion heater. Do i have to replace the entire cylinder or is there a gasket on the bottom of these boilers that can be replaced. Due to the leak an urgent reply would be appreciated!! Thanks Guys in advance
Unless you see something obvious leaking, - like immersion seal, you will have to get the cylinder replaced. As said, if it is old it was better all replaced anyhow for to give you trouble free years.
You need a G3 qualified person to repair, service or replace those unvented units.
Isolate that cylinder straight away and drain it down if you can. Had one of these earlier this year and it ruptured from the bottom and flooded the owners flat for for an entire day as it is fed off the mains. If you can't drain it then as a minimum switch off the water supply to it and get a G3 engineer in adapt to get it replaced.
Reply to the thread, titled "Hot water cylinder leaking" which is posted in Bathroom Advice on Plumbers Forums.
bogman,
macackau,
