View the thread, titled "hot water heater" which is posted in Bathroom Advice on UK Plumbers Forums.
T
tiling spread
I'm looking for a hot water heater that will have the power too run two hair dressers sinks and a small hand sink.
its for a mate the shop is in a shopping center (no gas supply).
there is one there now but they said its too small as they cant regulate the hot water from it.
keeps going hot cold all the time.
the drainage is all wafty too they had to fit a pump to pump out the water as its a low level drainage.
PS cant use end feed fittings. cant have a naked flame.
As dancin says, 15 litre sounds marginal for a haidresser - a couple of backwashes working at the same time would soon deplete it.
How about individual electric showers on the backwashes and a point of use instantaneous on the sink?
Most under counter water heaters are like a giant kettle and heat a volume of water that once used has to be filled and heated again. I think that 15l is not near enough capacity for commercial use, that is unless you fit 2 of them side by side if you have a lack of space and fit instantaneous water heaters. Watch the warranty with these things, many have a disclaimer stating for domestic use only and not for commercial use.
Reply to the thread, titled "hot water heater" which is posted in Bathroom Advice on Plumbers Forums.
