View the thread, titled "hot water is luke warm almost cold bacteria?" which is posted in Bathroom Advice on UK Plumbers Forums.
pavdineen
Hi
could someone please help me out with the problem i am having.I cannot have a shower or bath or wash up as the water from the taps is either cold or luke warm.My wife said that last year the plumber went into the loft and said we had bacteria in the tank and put some tablets in it. Could anyone confirm that this would be correct and if so could you please tell me where i can get these and what i have to do.
Hi
can anyone help me on the problem i am having. IF i have a shower or bath or turn any of the taps on the water is almost cold. The other year my wife called out a plumber and he said it was due to bacteria and put a tablet in the water tank in the loft could anyone confirm this and lead me down the right path as in what to do.
Uve left it this for a yr?
That's sounds outrageous, water cooling bacteria? Lololol. U believed him?
Tell me the setup of ur heating/hw system and we'll see if we can help u out.
we have a cold water tank in the loft and a combi heater. The problem we`had before was sorted by the plumber this current problem started 24 hours ago
your helpfull notttttttttttttttttttttttt
it is tank fed though, how would it be fed then ?
worcester 28cdi
They are normally fed direct from the rising water main, but supposing your water supply pressure is very low (below 1 Bar @ 15 Lpm) then I suppose it could be tank fed , but it would have to be quite a large tank
The hot water problem will not be bacteria related although,that may be a additional problem
The lack of hot water will probably be a boiler operational problem
imho
Please note original post thread edited for better explanation from poster
Not tank fed mate. Is there power to boiler(lights on)? Have you pressed the reset? can you get heating at all? if so try hot water while heating is on... that'll give us all some idea of whats happening mate. You really have to give more info
have seen some worcester combi's fed from a tank but this is the heating side only , where the air vent would of been a special fitting has been inserted there
Reply to the thread, titled "hot water is luke warm almost cold bacteria?" which is posted in Bathroom Advice on Plumbers Forums.
