View the thread, titled "Hot water no heating" which is posted in Bathroom Advice on UK Plumbers Forums.
T
Terrydoh
Hello guys
I'm primarily an installer but learning breakdown.
Im going out to see a eurocombi tomorrow that has hot water but no heating.
Apart from linking out the controls
Any ideas?
Thanks in advance
If hot water works but not central heating then look at the components that just involve central heating as pump fan etc will be ok as hot water works.
Good Luck!
Not teaching you to suck eggs mate but.... I've been to a number of these where the selector button has not been pressed. It's in for just water and out for heating / water...actually it may be the other way around but you get the idea?
Hello all
Went to job today, customers explanation of problem was incorrect.
They had no heating and intermittent hot water.
The diverter valve diaphragm had perished and the overheat stat was detached.
I can't see any evidence of a clip, is it just stuck on and if so what would be best to re stick it with
Reply to the thread, titled "Hot water no heating" which is posted in Bathroom Advice on Plumbers Forums.
