Hi there,
If anyone could help me on here with some good advice I'd really appreciate it. The system if got In my flat is a direct (electric element) cylinder and a water storage tank above it all in the hallway cupboard. The hot and cold outlets go into a Stuart turner negative head 1.5 bar twin pump. This provided our hot and cold water for the whole house except the cold tap in the kitchen sink.
The problem I have is that my cold water taps (pumped) always run hot for a few seconds then go cold. I checked to see if the thermostats had gone on the elements causing the water to overheat and fill the cold water storage tank with warm water. This isn't happening. I then phoned Stuart turner pumps technical dept and they said that it's a 19 year old pump, the hot water is crossing over at the expansion vessel and that I need a new one! (£475!!!!!).
Is there any other reason this could be happening??? There are some non return compression valves on the pipework after the pump. Could they have gone or do I need to face facts and buy a new pump??? It looks easy to put in. Just connect power and everything else is push fit.........
Any advice welcome!!!!
