R
Richiej
I'm fitting a new bath with a "coolfill" filler ( built into side of bath) via a shower type mixer valve recessed into the wall above the bath. The existing hot feed was on 22mm copper pipe thru to tap but the new mixer only has half inch "cylinder connectors" connectors the biggest outlet I can find is 15mm and if i used plastic with the insert would further reduce flow. could take days to fill bath on 15mm pipe.
I've been everywhere trying to get half inch with a 22mm outlet to increase the flow on my gravity fed system.
Does anyone make one? what alternatives are there. Some suggest fitting a pump just on the hot. not keen due to expense.
Help please
Help please
