C
Colin68
I attended a job today where the customer complained of hot water pressure issues after loft insulation fell in the header tank, cylinder is a vented indirect in the first floor b room with header in the loft .. drop of 22mm cold supply to the cylinder is about 3m. I cleaned out from the tank, drained cylinder, removed a small insulation plug from T at the base of the cylinder just above the d rain valve and thought yippee .. home early for dinner 🙂 ... not to be 🙁 checked the cylinder nothing in it, check basin and bath taps fore, all clear. Checked valve to isolate cold supply to cylinder also ok .. flow from the header tanks seems good .. cylinder only partially fills, any ideas ?, bit stumped as the flow from the header seems good 🙁
