Hot water taking ages to come through
View the thread, titled "Hot water taking ages to come through" which is posted in Boiler Advice Forum on UK Plumbers Forums.
Hi all,
I have what I will admit to being an old combi boiler in the house ( Potterton Performa ). It has a strange problem, when the heating is on the hot water comes through really quickly, but when the heating is off it takes an age, as in a whole washing up bowl full of cold before hot starts coming through. If I look at the boiler and start the hot tap, it almost seems like the the boiler isn't sensing the need for the water and takes an age for the burner to fire up, you can hear the pump running and moving the water but the burner doesn't kick in for around 30 seconds. The boiler has recently had a new diverter valve and a PCB. any ideas?
Miniman
Sounds normal
Boiler has to go through it’s sequence of opteration normally around 15-20 seconds then has to heat itself up as it’s cold
Hence the quicker operation when heating as everything is warm / hot
Reply to the thread, titled "Hot water taking ages to come through" which is posted in Boiler Advice Forum on Plumbers Forums.
Thread starter
Joined
Location
Essex
DIY or Homeowner
Thread Information
Title
Prefix
N/A
Forum
Boiler Advice Forum
Start date
Last reply date
Thread Tags
Tags Tags
None
Miniman,
ShaunCorbs,
