how can i get a hot water tap in garden building with only a cold feed
View the thread, titled "how can i get a hot water tap in garden building with only a cold feed" which is posted in UK Plumbers Forums on UK Plumbers Forums.
K
karen mcavenue
hi. i am putting a loo in my garden office but only have a cold water feed. can i get hot water without using one of those triton wall mounted mini electric heaters? eg is there an electric mixer tap or something i could use instead. saw something on amazon that maybe looked ok? cheers
So you would best go with point of use ,so the would mean getting a small electric water heater fitted ,the only issue you may need an electrician to run a thicker cable ,so 2.5mm is not enough. 6mm to 10mm depending on the kws.
Reply to the thread, titled "how can i get a hot water tap in garden building with only a cold feed" which is posted in UK Plumbers Forums on Plumbers Forums.
karen mcavenue,
karen mcavenue,
