How deep do you have to chase wall for wall mounted bib taps?
View the thread, titled "How deep do you have to chase wall for wall mounted bib taps?" which is posted in UK Plumbers Forums on UK Plumbers Forums.
Hi again
Second belfast sink related question, but different enough from the first to require a new thread...
Our preference is for the sink to be mounted in a corner, and for the pipes to be chased in for wall mounted bib taps. Presumably that means having enough room in the chase for the vertical pipes, 90 degree elbows, and whatever else is needed to connect the pipework to the taps.
Does anyone know how much depth is required for this kind of set up? Before choosing taps etc I want to make sure the wall will be suitable.
Thanks for all the help, it's so useful having forums to address all the unanswered questions that keep popping up!
Cheers
Many thanks for the replies.
Is this the sort of thing you mean?
https://www.NoLinkingToThis/p/flomasta-end-feed-adapting-90-wall-plate-elbow-15mm-x/91665
With the end of the threaded section sitting flush to the wall's surface. And the tap then screws into that?
If so:
1. At the pipe end, is a solder or compression joint preferable when chased in?
2. Would you recommended insulating the pipes? Only a length of around 30-40cm of pipe will be chased in per pipe.
Thanks again
Reply to the thread, titled "How deep do you have to chase wall for wall mounted bib taps?" which is posted in UK Plumbers Forums on Plumbers Forums.
Plumb Line,
Plumb Line,
