How do I connect to this ground toilet pipe.
View the thread, titled "How do I connect to this ground toilet pipe." which is posted in Boiler Advice Forum on UK Plumbers Forums.
Underfloor pipe. How do I connect? The pipe is made of pot I think and it’s broken. My flexible toilet pipe won’t go into it properly. It’s 10cm in diameter. Thank you in advance.
You can purchase a adaptor which will get you from the hep sleeve pipe to standard 110mm plastic pipe. Kop
Either what @king of pipes has suggested or something like an extension A multikwik with a 90 bent multikwik (2190) or if it's possible a long tail 90 bent multikwik.
Looking at the damage to the clay pipe, I think the drain adaptor will bottom out before it makes a good seal.
I would go with Aquarius’ suggestion and use a mcalpine pan connector extension, followed by a 90 degree pan connector. The extension has a longer section of fins, however it may still be necessary to carefully excavate around the clay to allow a good connection to be made.
Think of it as an archeological excavation rather than a builder’s one, go steady....
Reply to the thread, titled "How do I connect to this ground toilet pipe." which is posted in Boiler Advice Forum on Plumbers Forums.
Nicholas Lambert,
Ben-gee,
