View the thread, titled "How do you apply your flux?" which is posted in UK Plumbers Forums on UK Plumbers Forums.
Its amazing wat you find in peoples house I once found a flue on a room sealed boiler that was on an outside wall but the flue went vertical in to the loft then on a 45 down through the eaves and poped out didnt take a picture but wish I had there was no obstructions not sure why they didnt go straight out the wall strange
I found one installation, where the customer had installed his own boiler, and luckilly not been able to get it to work.
He's used self tappers to screw the old flue to the new boiler (a Biasi boiler - nice).
Anyway I Riddor'd that one. Don't do that very often.
I switched to powerflow today. Been doing a bit of soldering outside on a portable workbench at a job as soldering in a cupboard was a night mare.
Anyway I found that being outside (which is very cold in the snow), laco was burning off before I even took the chill out of the pipe. Power flow on the other hand was my saving grace. Think ill keep the laco in the shed with the other rubbish I don't use!
Thinly with a brush on the pipe and fitting then give the pipe a bit of a twist in the fitting
"EVERFLUX" and steel wool and rub off anything that looks oxidised including my brains...And a good flux brush...Has anyone tried buying these brushes from shops they a total rip-off.
On the pipe with the solder and twist as you insert to the joint as many have said, if your posh use a brush 🙂
All the soldering I did today - I just fluxed the pipe and no fittings fluxed at all. I was using yorkshire fittings though.
Not turned the water back on yet as finishing off tomorrow 🙂
Wish me luck!
Wish me luck!
All the soldering you did???? I ended up doing your job on my way home....
A day on site then a bath and shower on way home😱....cheers for the referral im knackered now🙂
Hehe I was on day-rate yesterday on a refurb, back there this afternoon too, I just wouldn't of had time to do that other job, glad you sorted it mate 😉
Just flux on pipe but both pipe and fitting need to be cleaned with abrasive strip then push in and twist.
back to basics, surely the point is to use a small paint brush, clean the pipe and fitting with wire wool, i use the wire brushes to clean the fittings then apply a little flux, and the important point is to not use too much solder and to move the flame, ive seem fittings burnt black by too powerful a flame and the plumber not moving it to help the solder run around fully, im also old school and dont like to see solder snots hanging from the fittings
The same one as me by the sounds of it!
Wire wool can break up & leave small pieces of the metal on the pipe causing problems with the solder taking properly!!
Small strands of wool get left in the joint, over time these corrode and you get leaks..........simples 🙂
Or have you too much experience ?
been using wirewool for more than 30years, never had any issues, but its nice to see you have, i check my pipe before i insert it into the fitting.
You mean you have never noticed any issues. As well as the potential for leaving contaminants on the pipe if you use it near sanitary ware it can leave rust marks after a few hours.
Reply to the thread, titled "How do you apply your flux?" which is posted in UK Plumbers Forums on Plumbers Forums.
Thread starter
Dannypipe
Subscribed
Joined
Location
Tunbridge Wells
Thread Information
Title
Prefix
N/A
Forum
UK Plumbers Forums
Start date
Last reply date
Thread Tags
Tags Tags
None
Dannypipe,
Dan,
