Guest viewing limit reached
How do you drain down the DHW only from a combi boiler?
View the thread, titled "How do you drain down the DHW only from a combi boiler?" which is posted in Boiler Advice Forum on UK Plumbers Forums.
G
Geordie George
Hi I have a Remeha 39c Combi boiler. It sufferers from a high pitched whistling sound every time I use the hot water. This is annoying but everything works OK ...plenty hot water and the heating works fine.
I'm think it's from the flow switch so I want to swap it for a spare and de-scale the old one.
The last time I tried this I closed the boiler cold supply valve on the boiler and turned on the kitchen sink tap which is only about 30cm lower than boiler. Very little water siphoned out and when I started to remove the flow switch there was a considerable flow which I had to let drain out of the boiler base....what a mess!
The DHW flow pipework goes upwards from the boiler to the upstairs bathroom and shower before going down to the ground floor taps so draining off is difficult...at least for me!
The lowest DHW access point is an unused ground floor washing m/c hot supply .....should I try draining via this point to increase the available head of water?
No he shouldn't.
We cannot and will not give advice on the installation or repair of boilers, cookers or ANY gas appliances for your own safety.
Please go to Gas Safe Register | Ensure your gas engineer is registered. or post a thread in the 'I'm looking for a plumber / gas engineer' section of these forums remembering to include your location. [DLMURL="http://www.ukplumbersforums.co.uk/im-looking-plumber-gas-engineer/"]I'm looking for a Plumber or Gas Engineer[/DLMURL]
If you are gsr please increase your post count to 10+ then send a PM (Private Message) with your gsr details to either Gas man - View Profile: gas man - Plumbing Forum | Plumbing Advice | Plumbers Forums | A forum for plumbers advice in the UK or Redsaw - View Profile: REDSAW - Plumbing Forum | Plumbing Advice | Plumbers Forums | A forum for plumbers advice in the UK who will check you and then give you access to the gsr private forum.
Providing gas-related advice to anybody who should not be touching gas and cannot prove their competence is unacceptable. We will take whatever action we deem appropriate to prevent such advice being given
Thank you.
UKPF TA's, Mods and Admin teams.
http://www.ukplumbersforums.co.uk/central-heating-forum/42241-notice-gas-safety-related-advice.html
Reply to the thread, titled "How do you drain down the DHW only from a combi boiler?" which is posted in Boiler Advice Forum on Plumbers Forums.
Geordie George,
Dotty,
