How many gas faults can you spot on this guys
View the thread, titled "How many gas faults can you spot on this guys" which is posted in Gas Engineers Forum on UK Plumbers Forums.
king of pipes
Subscribed
Gas supply and meter under the stairs in a 5 bed detached house .
A few also the reg is on the list to be changed might be worth giving the gas/ utility nets a buzz
Bracketing zero , compression fitting gas butterfly type valve no no under stairs , would you really design a 5 bed house and put the inlet gas supply and meter under the stairs which in a emergency would be the main route of escape not even fire proofed and this was in guess a architects house fm see it every week
As above + Also Looks like there's a piece of masonry wedged under the gas pipe to support it instead of it being clipped & the gas pipe is not protected/factory sleeved where it runs across the concrete floor & the meter is sat on some bricks.
Yeh few issues , anaconda on outlet , bracket not fixed, the earth although is there must be 600 or b4 the first tee piece,
Good should @pipeman- with the fire resistant enclosure missing since its under the stairs ,,
Reply to the thread, titled "How many gas faults can you spot on this guys" which is posted in Gas Engineers Forum on Plumbers Forums.
king of pipes,
king of pipes,
