How many have you lot changed?
View the thread, titled "How many have you lot changed?" which is posted in UK Plumbers Forums on UK Plumbers Forums.
quality
I have replace the inspection cover on 2 occasions and its been the sump thats cracked so I just replace the whole sump on them now to be certain. Pretty bad really as I have done quite a few
Whats involved in changing the sump ?
I have never done one because all my customers have combis and from what I have heard they only go on heat-only’s
Ive done more on combis than heat only but then thats probably because there's more combis than heat only out there
Yep I changed a few as well, I used to just change the cover but like Quality says above, I've found it to be the sump most times and wasted time just replacing the cover. So I too swap the sump out now just to be sure.
Done one. Was quite easy. Just loosen the heat exchanger holding screw slightly to ease the back clips.
Reply to the thread, titled "How many have you lot changed?" which is posted in UK Plumbers Forums on Plumbers Forums.
quality,
Vee,
