combi will only run one outlet at a time!
I don't often disagree with you BUT....
Now I'm not a plumber, I don't now the KW of our Remeha Avanta plus combi and I don't know our incoming water main pressure.
And, we do not have any eco, low flow taps in our house
I wonder if I'm going mad so did a little experiment to confirm what i know.
I turn on two hot taps downstairs (boiler is downstairs) good strong flow and hot from both.
Yes there must have been a drop in temperature and in pressure but not significant.
Then I went upstairs and turned on the tap - still good pressure from all but temperature is more warm than hot now we 3 taps going.
Turned off the upstairs tap turned on the shower - you know that fancy rain head thing that must use tonnes of water - the pressure was still good enough for that - though with 3 hot taps going the temperature is warm.
My conclusion is that with strong mains pressure and combi boiler with big enough KW output then you can have 2 hot taps/ outlets going FULL - no problem.
And I could have had a cold tap on as well.
I already know this from experience as 5 people live here the water is being used constantly - thank goodness we are not on a meter!
As I so often read on this forum that what happen in my house is not possible I thought I'd just check it again. One day I might try to use 2 showers at the same time!
