Guest viewing is limited
How many turns of pfte, to stop radiator leaking?
View the thread, titled "How many turns of pfte, to stop radiator leaking?" which is posted in UK Plumbers Forums on UK Plumbers Forums.
Nas
The only leak I always struggle with is where the valve is joined to a radiator. So here's a question for all you plumbers. How many turns of ptfe do you put on the valve to stop it leaking? or do you have any other tips??
Do you mean the !/2 chrome thread? I never really count the turns,I guess it's around 10. It depends on the 2 fittings really and how closely the threads fit. It's something you'll get a feel for with experience. I still use boss white and hemp in certain situations, particularly on connections to solid fuel appliances(not potable water though!) If I use it on rad tail I run a hacksaw blade across the threads to stop it slipping. Do other people still use it?or am I being old fashioned!!
10-12 turns on rads. Its the cheap towel rails with no decent female thread that causes me problems sometimes, so out with the hemp and paste, might try some ptfe thread next time, dont like using it as it costs so much, lol
i use probably about 10+ turns building up a taper along the thread on the tail, if its not a nice tight fit take off and redo as the tollerances on these threads can vary. some plumbers also put a tiny wipe of paste on the first thread.
I use 10 - 15 turns onto a new rad and if its onto a used rad i add some jointing paste as well . It may be overkill but it works !
i dont really count, but when i do use it if it leaks i add more
was going to say one more than is needed 🙂
I do as fdph but use a little lsx
When making joints it is important to know what you are sealing,it is surprising how many do not,thus threads taped on compression fittings ect
In this case it is the space between the male thread on rad and female thread on fitting,so a lot depends on the quality of these two threads
You will notice on a good quality towel rails or rads a few turns will do,on cheaper units,with lower quality engineering, it will take more,always make a slight taper though to allow tape to be trapped in thread when doing up
This is why I like Lsx also and others loctite 55 as not only does it seal joint but also holds it in place also ,if poor quality engineered thread involved
imho
Thanks for all the replies folks.
Excuse my ignorance whats fdph and lsx? So far loctite 55 sounds like a winner for me.
Has anyone had any experience of liquid PTFE?? or loctite 572?
I recommend Loctite 55 and Boss White paste, never leaks. The extra pennies you spend using this will be saved in time spent repairing leaks.
unlucky for some but i always do 13 turns for rads (its kinda become an obsessive habbit), i used to do about 20 but over the years you try and find out how low you can go, i found 11 to be about water tight so always 2 more wraps. probably done 2000 rads with 13 turns and never had a leak on one. now cheap nasty towel rads are a different story lol
ptfe about 12 turns but 55 is much better about 7 turns and a little paste
for towel rails i try to find the vaves that have the rubber washers that seal like the vent and plug do in fact if i get that type of valve i tend to keep a few of the tails just for towel rails
Reply to the thread, titled "How many turns of pfte, to stop radiator leaking?" which is posted in UK Plumbers Forums on Plumbers Forums.
Nas,
fuzzy,
