How much solder for 15mm pipe?
View the thread, titled "How much solder for 15mm pipe?" which is posted in DIY Plumbing Advice on UK Plumbers Forums.
Hi All,
I hope you are doing well.
I have this 3.25mm lead-free grade 99c solder wire. I know that the good practice to bend the wire before soldering so you know exactly how much it is absorbed by the flux. I know too little isn't good and too much is as bad.
I need to connect two 15mm pipes with a straight connector.
Let the heat of the metal melt the solder (not the flame).
Apply solder at the base (lowest point) so you can see it flood the fitting.
Don't burn the flux.
Practice makes perfect!
Reply to the thread, titled "How much solder for 15mm pipe?" which is posted in DIY Plumbing Advice on Plumbers Forums.
JohnMalcolm,
Timmy D,
