how to check the flue performance of air heater?
View the thread, titled "how to check the flue performance of air heater?" which is posted in Air Sourced Heat Pumps Advice Forum on UK Plumbers Forums.
bluesky
i am going to do the flue performance test of a Johnson and Starley air heater. But cannot find where is the best place to test the flue. Anyone has done this before?
cheers
cheers
done one of these at college me thinks and we were instructed to take the analysis from the primary flue through the back of the draft diverter? hope this helps. sure someone qualified will either confirm this or correct me 🙂
thanks diamondgas, it is hi-spec J50, if there is no access can we make it N/A?
You should be able to pop a smoke bomb in the burner chamber I think? I usually pop them in there so you're testing the whole path through the main heatex... Best to warm the flue up first though as the main chamber is usually pretty sluggish if not heated! At least at the burner chamber you're testing the whole of the flue, primary and secondary! If there's a problem you'll sharp find out!!!
Reply to the thread, titled "how to check the flue performance of air heater?" which is posted in Air Sourced Heat Pumps Advice Forum on Plumbers Forums.
bluesky,
diamondgas,
