View the thread, titled "How to choose the right Worcester boiler" which is posted in Boiler Advice Forum on UK Plumbers Forums.
I am sure that why there are so many responses against Worcester. They always come up very high in the review sites
What about the potterton titanium boiler? It comes with 7years guarantee.
Worcester feature highly on review sites for a number of reasons. They have a HUGE marketing budget. They were extremely good boilers, and are still enjoying the reputation they deserved back then, even though the new boilers are not of the same quality. They work hand-in-glove with Which magazine, so they are always featured as "Best buy". People leaving reviews only generally have experience of their own shiny new (expensive) boiler. Basic psychology tells us that they are not going to give it a bad review, as that would make them look foolish. Installers and breakdown engineers see the common faults, and get the chance to compare against other brands.
Anyone got an opinion?
Baxi Platinum 33 HE
or
Baxi Duotec 33
Can't comment on the Baxi but gasman, a senior member on here really likes them. For my money, you can't go wrong with an Ideal Vogue. Stainless steel heat exchanger, 10-year warranty, quiet, looks good, excellent modulation ratio (very efficient). Or if you're open to a less well-known but excellently engineered product, Intergas is one to go for. Just four moving parts (so basically very little to go wrong), no diverter valve (the Achilles heel of all combis), huge waterways (so no issues with hot water performance deteriorating due to sludge or limescale). Not a pretty boiler but does the job very very well at a reasonable price point.
Thanks masoon for the detailed response. Makes sense now.
Which intergas combi boiler would recommend for my case.
2 beds
1 bathroom
1 en suite
7 rads
Thx
2 beds
1 bathroom
1 en suite
7 rads
Thx
Either the Combi Compact HRE 24/18 or the new Eco RF. The main difference is that the Eco RF has a built-in receiver for a wireless room stat.
I should add that if your incoming mains has a really good flow rate, then you should choose a higher KW-rated boiler to take advantage of the hot water performance, and set the heating output to the requirements of the property.
I have been checking the sound level of the Combi Compact HRE 24 and it says 45dB. This is fairly noisy when other boilers achieve much lower sound level.
This boiler is going to be in my cupboard which is located in my bedroom so it needs to be as quieter as possible
I should have included this when I mentioned what type of boiler I was looking for because this is a high priority as it being reliable.
what boilers are in the 30dB and as reliable as the intergas?
45dB is not very loud at all, especially if the boiler is in a cupboard...
Unless you lie in bed while your heatings on, or run the hot tap from your bed. You'll be ok.
yes it might happen that in winter the heating will be on in the night and someone else has a shower when i am in bed
45dBA is approximately as noisy as a computer fan. Really not noisy at all - in fact, unless your hearing is hypersensitive you'd just tune it out. If the boiler is going in a cupboard then you'll be pretty much unaware of it operating.
Read the thread from the beginning. Or just ignore all our combined experience..
His opinion matters not a jot. What with him posting from a known spam source and all.
If noise is an issue sound proof the cupboard im sure there are many cost effective solutions like shoving loads of cloths and other associated crap that would deaden the sound.
Most modern boiler are very quiet these days.
I think over the last 10 winters my boiler has come on about 2-3 times in the middle of the night due temps dropping so low. And you would really only set it to come on 10-20 mins before you are due to get up for work on a week day.
In my mind the best boiler worcester ever took out is the greenstar Classic cdi, a brilliant boiler in every way , i fitted Bosch for years but went off the newer range and my personal experience is the classic is the bogs dollocks , I moved to the ideal vogues as ten year warranty is a big selling point, also it's a cracker of boiler
are those the 2 boilers you'd recommend as i need advice badly
Vaillants are good and Baxi Duo Tec's are a good boiler as well.
Get a good local installer round to give you a quote and advice needs a site vist , if you must have worcester bosch the greenstar classic 34cdi would be my choice cheers kop
Worcestor boilers don't have low water pressure safety cut off, or blocked condensate safety cut off switches.
Changing a simple part like a prv can involve the removal of the boiler from the wall.
It's the only manufacturer that I'm aware of with these possibly catastrophic omissions, and yet they're the best selling boiler in the U.K.
The question is why? Good advertising campaigns perhaps?
I am more of a Vaillant man myself as stated before. But I am sure that Worcester now do boilers with prv's inside the boiler. Also I am sure they say that there condense pipes cannot block because the condense trap dumps the whole lot once it is full. So if the condense pipe external to the boiler is ran properly it will not block. But I may be wrong😀
Reply to the thread, titled "How to choose the right Worcester boiler" which is posted in Boiler Advice Forum on Plumbers Forums.
