V
Volunteer
Hi, I have a dual coil, unvented cylinder with what I think is a pressure relief valve fitted on the end of a 15mm pipe which is T'd off the 22mm feed from the boiler to the top coil. The valve is leaking when the boiler is on or off and I want to remove it for inspection but when cold main is turned off and I open a hot tap I suspect there is still water in the top 1/4 of the cylinder. How do I make sure I have drained the water level below the top coil input joint before removing the valve? Many Thanks
