C
colinbruce123
Hi i have fitted a thermostatic shower but my combination boiler doesn't allow enough hot water pressure and flow. Can anyone make any suggestions? I've thought about fitting a pressure restricting valve to the cold line, or purchasing a water heater, to supply the shower. Would this be an option? Any help would be appreciated.
Why did you fit this shower? You state that your combination boiler doesn't allow enough hot water pressure and flow, so why did you fit this shower? It would tell you on the installation instruction the requirements for installation, could have saved yourself a job. As TbServices said "An option would be to CALL A PLUMBER"
a combi boiler will usually give a good shower performance, compared say to an electric shower, but not so good maybe compared to a 5 bar pump or an unvented cylinder. what is your expectation?
how much pressure and flow does it give??
what size is the boiler?
what size is the shower head??
what is the pressure and flow to the property?
is the pressure and flow to the other outlets better than the shower?
